Sherman
- Raymond Wa
I have a temporary portable steel shower unit with 10 showers and a hot water heater, 208 volt, 3 wire in the corner of the unit. The shower unit is fed from an "I" line MDP, which is fed by a generator with a bonded neutral. The panel has a driven ground rod as an equipment ground.
I am being told to run a #2 ground wire from the hot water heater to a separate ground rod for that hot water heater. I feel this is a code violation. Correct me if I am wrong.
