I have a question about the location of the ground rod for a grounding electrode system. I usually provide a ground rod connected to the buidling steel, the water pipe and to the main service disconnect. I have always thought that the grounding electrode rod should be connected to the main service disconnect. I have a situation where I am relocating the service meter and ct away from the building. I am adding a new fused automatic transfer switch at the new location. Should I provide a new ground rod at the new ats and connect it to the existing rod at the building? The distance from the new service to the building is about 200 feet. At the building there is no disconnect. Currently, there are five breakers in the main panel that are each serving as a service disconnect.
