Juliolagos
- Mexico City
Can my structure rebar be my grounding electrode, will it deteriorate; my tests show it has less resistance than a rod making it ideal for grounding which seems to not be working as ground at all , seven deadly grounding sins says it will deteriorate the structure. I tried the ground rod in a well adobe the water and it’s not showing any grounding capacity , does a ground rod even work as intended some all ground is not the same diferente resistance how does one compensate
