Samardas
- Los Angeles, CA, United States
- Electrical Engineer
I have a service disconnect panel with a utility meter for an 800A, 480V, 3 Phase service. This is an old warehouse where this new service panel will be installed at a location much further from the existing service which will be removed. I am looking at the NEC 250 section, but not sure what type grounding I should recommend. For example, can I show a new ground rod/or pipe and connect it to the ground bus of the panel? Also, can I show the neutral and ground bus to be bonded and the panel to be grounded to the ground bus? Do I also need another ground (say, UFER) or cold water pipe ground to be connected to the ground bus? Customer is in a rush and I need help as soon as possible. How can you please help? I am attaching a partial single line for your reference. Thanks a LOT.
