GuruLal
- North Carolina
- Engineer
Question about grounding gas pipes.
1. I've realized that my gas pipes may not be properly bonded. I see some current on that gas pipe, about 2 mA or so, current is trying to go to ground via this gas pipe conduit, this is probably not Normal. If we bond this pipe, should we connect it directly to the house ground or should it be taken to the subpanel instead?
What is code and a proper protocol for bonding gas pipes.
