Leos98
- Westchester, NY
Hello,
I?m currently working on a design for a summer camp. The design consists of an underground 4800V delta system. The existing system is overhead but because of the damage cause by trees during past years we are proposing an underground system. The utility company brings the 4800V delta service to a pole outside the camp in which it meters the service and the customer overhead system begins. Our plan is to begin our underground service at such pole, run underground for about 150FT and then install a Sectionalizing cabinet from which we will tap to three different pad mounted transformers thru out the camp. We want to run 3-#2AWG, 8KV, shielded wire from OKONITE in PVC conduit from the sectionalizing cabinet to each of the 45KVA transformers. The question: Do I need to run a ground wire in each of those conduits? I?m pretty sure I do not have to because I?m setting my ground at each of the transformers but I have not been able to find something in the NEC that will backup my design.
Thanks!
Thanks!
