The image below depicts the factory wiring for 1200:5 MR CTs connected to an overcurrent relay. If instead you wanted to connect the relay to taps X2-X4 (to obtain a 600:5 ratio), what would be the correct way to do it?
Would you still leave X5 as the grounded tap? Or would you move your grounding to the new center point (X4)?
