Bugman1400
- Charlotte, NC
Whether you ground the polarity side or the non-polarity side is a matter of application. Some devices use the non-polarity instead.....metering comes to mind since many times it uses the opposite side that of the relaying. There is also the off-chance that the CT was incorrectly installed in reverse.You don't ground polarity. Polarity is the smaller number and goes to the instrument (X1 for your example). The higher of the used numbers gets grounded (X2 for your example).
