zach_zachary1@yahoo.com
- Apex,NC
I work a large municipal wastewater plant. We have 40-50 pole mounted 480 volt 2 phase, high pressure sodium area lights. Its aluminium conduit with a NEMA 4x stainless steel junction box at the base of the light pole. These NEMA 4x boxes contain splices. None of the boxes are grounded. There is an equipment grounding conductor but the egc is not grounded to the box. Does the NEC require these boxes to be grounded? Are there exemptions?
Thanks!
Thanks!
