- Chapel Hill, NC
- Retired Electrical Contractor
I guess the big question is what is likely to be energized? If I have NM cable and use metal connectors to attach to a PVC JB is the connector likely to be energized. My gut tells me that this is an illegal install yet I see it all the time with in line plastic fans.
If the connector is likely to be installed then why would a staple not fall into the same category. The connector is only likely to be energized if you over tighten the screws in much the same way that a staple may be energized from smashing the dang thing too hard.
Any art. that specifically calls for all metal connectors to be grounded?
