I'm sure this question has come up before, But I can't seem to find any threads about it.
Anyway, I have a 40HP motor mounted on a carriage. The carriage moves along a beam on bearings.
What is the grounding requirement?
Do I need a separate EGC from the carriage to the beam, or since the motor frame is secured to the steel carriage, will the motor cable ground be sufficient?
Thanks,
Doug :-?
Thanks,
Doug :-?
