white stallion
- El Paso, Texas
Have an installation with three feeders, each feeder is made up of three 3-500 KCMIL 2400V parallel feeders for approximate rating of 1320 Amps. The service originates at utility from three individual transformers and terminates at the medium voltage switchgear. All feeder cables are to be run in cable tray, no conduits. The question is: does each parallel cable run require its separate ground conductor rated for the full capacity of the three parallel feeders? Since there is no conduits involved, can only one ground conductor be used for all 9 - 500 KCMIL feeder?
