Alwayslearningelec
- NJ
- Estimator
Have about 1000' of fence that needs to be grounded. This detail seems to indicate a bare conductor daisy chained between ground rods. Kind of like a grounding/counterpoise loop.
Is that needed? Couldn't you just go from the fence to the ground rod at each location?
If you need the conductor between all ground rods how would you size? THey do show 4/0 but only from ground rod to fence. Thanks
