Grounding of messanger cable
michaeldlynch
New member
A messenger cable is currently supporting a single phase 240 volt (two wires) lighting load (60 amps).The messenger cable was the grounded neutral on the old 120 volt lighting system.Can I use the messenger as an equipment ground for the light fixtures which are currently ungrounded.
Re: Grounding of messanger cable
Assuming that you remove it from the neutral buss and tag it to the Equipment Grounding buss.
frank
