SMKDEB1
- Terre Haute, IN
I have a portable safety shower trailer that has a 8 kw generator for emergency use and a 15KVA, 480V-120/240V, 1-PHASE transformer mounted on the trailer for normal use. The 15KVA transformer is fed from a remote 480V panel via a SO cord. I am installing a manual transfer switch on the trailer that will isolate the two sources from one another.
All of the load from the generator and the transfomer is contained to the portable trailer. The trailer is to be used as a temporary safety shower.
Do I need to ground the transformer neutral?
Do I need to ground the trailer to a ground rod?
