bstermer
New member
- Chicago, Illinois
A steel pedestrian bridge over freight rail tracks in a rail freight yard. The bridge is approximately 20 feet high and has no electrical equipment mounted on it. The bridge is specifically for routing pedestrians over the freight without incident. Does NEC require a steel pedestrian bridge with no electrical equipment attached to have any type of grounding? If so, which specific NEC Article addresses this issue? Thank you.
