Grounding requirements for Jacuzzi
kdrum
New member
New York
What is the grounding requirements for a jacuzzi installed in a single family dwelling? I was told that in addition to GFCI protection, the jacuzzi motor has to be grounded to a cold water pipe - true?
Re: Grounding requirements for Jacuzzi
Are you talking hydro massage tub? If so read 680.74 2002 NEC for bonding requirements.
[ March 04, 2003, 01:07 PM: Message edited by: electricmanscott ]
Jacuzzi is a brand name but I suspect you mean Spa or Hot tub. The bonding requirements for these are at Article 680.42(B) for outdoor installations and 680.43(D) for indoor installations. In either case, the pump will need to be bonded by means in part (E), and part (F) describes the grounding of this equipment.
