Toros
- Tujunga, CA
Hi,
I am installing a supplemental copper rod at existing 1200A, 3-ph. service that has only grounding system electrode/conductor to the main water pipe. now, Can I connect the GEC from the new grounding ro to the same main water pipe where other one is already connected;
or I have to run it all the way to grounding/neutral bus of the existing service??????
Thank you
Thank you
