kentwc
- morgan ut united states
We are installing a 3750KVA transformer that is 12470 Delta to 480Y/277. We are going to two 2000 amp main distribution panels. We are going to run 5-600mcm cables per phase but had a question on the grounding side of things. We are running under ground for about 20 feet with 10-3 1/2" PVC conduits up to a cable tray that will run the remaining 110 Ft. Do we have to run a 250mcm grounding conductor in each race way to grounding lugs on the cable tray and then run two 250mcm grounding conductors the remaining way in the cable tray, which one will land in each distribution panel?
In the drawing it shows the transformer underground conduit and the cable tray.
Thanks in advance!!
Thanks in advance!!
