jordyn16
- Covina, Ca.
I took over a job that some other electrician installed 2 - 200-amp sub-panels. An inspector said that all romex ground wires must be seperatly terminated to the ground bar. I thought that the ground wires could be attached with a grounding barrel an then a remaining ground wire could be terminated to the ground bar. Lets say install a grounding barrel to three romex # 12 ground wires and cut two wires short and install the remaining ground wire to the ground bar
