Since i am not an american engineer so, some of the grounding terms is not clear for me, please correct me if i am wrong,
- "EGC" the grounding conductor that bonds the electrical equipments together and provides an alternative path with low impedance during fault current
- "GEC" the grounding conductor that bonds the electrical equipment to grounding rod/water pipes/(nearest grounding electrodes)
- "Bonding jumper" the grounding conductor that bonds the metal parts together to provide a continuous path during fault current (sometimes getting confused with "GEC")
Also in IEC standards (may someone confirm or correct):
- "EGC" is "PE"
- "GEC" is "Earthing cable"
- "Bonding jumper" is "Equipotential bonding"
- "EGC" is "PE"
