pegggu
- Los Angeles
in a 120V streetlighting system (1 hot, 1 neutral), if the neutral was bonded to a grounding lug at each pole, what purpose does this serve and what would happen in the case of a fault?
in a 240V streetlighting system (2 hots, 1 ground). if a neutral was also installed from the source throughout the circuit, would it serve any purpose? if this neutral was also bonded to the grounding lug at each pole and there was a ground fault, what would happen in this case, would the neutral become energized and become a return path to the source?
thanks in advance!!
thanks in advance!!
