keithcalhoun
I have a friend that has experienced water leaks in the copper water line coming into his condo. The plumber said that connecting the electrical ground to the copper water line is causing many pipes to leak. He did not mention the mechanism that he claims is causing the problem. Has anyone heard of this being a problem, particularly since the code requires a ground to the copper water line within 6 feet of the exit frm the building? Is there a valid concern for water leaks, and if so, what could be causing the problem? :?:
