GerryB
- woodbridge, ct. USA
I was watching a Mike Holt video where he was talking about the danger of having for example a ground rod for a solar array not run back to the main GEC. He explained a difference in potential and the possibility of high current flowing between the two, (and through the house). He had an easy way to think of it, "everything above the ground should be bonded together, everything below the ground should be bonded together, and there should only be one spot where they are tied together. That is how I understood it, which made me think of a detached garage. Isn't a detached garage treated as a sub panel but ground rods should be added at the garage? Am I understanding this correctly? And wouldn't that be two separate ground points.
