Varshini Guduru
- New Jersey
- Project Engineer
Hi there , I'm working on one of the Solar Distribution generation projects which requires a grounding transformer as per the Utility system impact studies . Till date , I have had designed/ used grounding transformer with G-WYE on the high side and delta (3phase, 3wire) on the low side with 480V. I have received a design from our outsourcing partners with 240V delta on the low side (We are using a 75kVA, 12.47kV WYE Grounded /240V delta) - that begin said to my experience , 240V delta would require a Neutral with center tapped (As in case of High leg delta ) , but could a 240V 3phase 3 wire delta with no neutral be used on the low side of the grounding transformer. Please advise . Thanks in advance.
