PaTerminator
- Lehigh Valley PA
- Electrical Contractor
I'm replacing two 100 a fuseboxes with two 100 a panels.(located side by side)
I want to only run one #6 to the rods and only one #4 for the water pipe.
Is there any way to do this without splicing and using crimp connectors or exothermic welding ?
My supply house wasn't familiar with the busbar alternative either in 250.64 (C)...
Do I loop thru one panel and terminate it to the second? (Similar to how you jump from one ground rod to the other)
