DJordan23
- Waterloo, IA
- Electrical Engineer
I believe this is the model that the electrician told me was getting installedWhat brand of cover is that? The installation looks completely wrong.
You are correct. This does look accurate to the one installed.Looks like this cover, Intermatic WP1010MXD.
Thank you for the response. What does the acronym for IOW mean?I agree with Infinity. The instructions say a ground wire is included and the receptacle mounting screw should pass through the eyelet, IOW's make contact with the device yoke, the way it's installed in the picture is wrong.
Then as Roger stated the bonding jumper should connect to the screw on the receptacle as shown in one of the photos from the link.You are correct. This does look accurate to the one installed.
Thanks Infinity this should wrap up this thread.Then as Roger stated the bonding jumper should connect to the screw on the receptacle as shown in one of the photos from the link.
No problem sir. Thanks for clarifying.In Other Words, the apostrophe and s was wrong too![]()
