By reading section 250.52 (A)1 in the 2005 NEC I am interpreting this as you must go to the water main, if water is available in the building, to get part of your grounding. Am I interpreting the exception as saying I can hit that water pipe anywhere in the building as long as it is an individually owned commercial or industrial structure serviced by authorized personnel, such as a maintenance department? I can see I may need to bond around the meter with a jumper wire but otherwise, is my interpretation correct?
