Jim Hughes71
I had a situation where I was inspecting a disconnect switch on a single phase system. The electrician pulled in 4 wires. Two hot a neutral and a ground. He terminated everything correctly but ran the ground to a lug on the enclosure instead of landing it on the Neutral/grounding buss. Is this correct? If it is Why? He said that if you land the ground on the Neutral/ground buss and there is a short in the enclosure then it could back feed through the Neutral. could someone enlighted me please.
