I am installing new ac units with varible speed drives. The Building was built in the early 70's,
there are no grounding buses in our panels. The conduit served as utility ground, what should I do to ground the unit correctly? I do not no what the code was in the 70's or what type of earth grounding system we have. Could I use building steel or should I go back to switch gear for grounding.
