Can the cold water piping ground be installed at the service panel? What I have is a service disconnect located about 150' from the service disconnect. The water service is located at the location of the service panel. My question is that may I install the cold water ground to the service panel and install a conductor from the ground bar at the service panel back to the service disconnect, keeping the service panel's neutral and ground seperate?
Thanks
Thanks
