mike7330
- North America
Yes I do, and do I think it's a good idea to intsall a ground rod for lightning protection, Yes.
So, a pole in you opinion doesn't meet the definition of being "built or constructed?Yes I do, and do I think it's a good idea to intsall a ground rod for lightning protection, Yes.
Roger
You pick and then tell us why it would matter as far as the NEC is concerndwood or metal?
roger
I answer tomorrow, long day for me! I would like to continue with this.
mike
If I did not install a rod in most of those cases I should win the argument with the inspector. 250.32(A) Exception.Bow, the reason for the ground rod is not in question and I will say again, read the definition of "Structure". An inspector could very easily require one at every pole, pedastal, porta john, (if fed with power) etc... and you would have a losing argument convincing him it is not required.
Roger
I agree, I was a little loose with saying an inspector could require one at "every" I should have said "at some". However, it still wouldn't matter what the structure is or what it is made of.If I did not install a rod in most of those cases I should win the argument with the inspector. 250.32(A) Exception.
Roger
Wood or metal.
Wood you can?t pass through, metal you can.
250.32 (A) does not say pass through in the text
So a grounding electrode would be required!
But the exception would come into play for a single circuit
As asked by the op.
I still believe the ground rod in good for lightning protection
What are your reasons for the adding the grounding electrode?
Can?t recall off hand, but didn?t Mike Holt write something on metal light poles not being grounded properly? I know in our state, a dog was killed, and I believe a person. They later found that they would need to correct the grounding for some or all of their light poles. I have this somewhere????..I?ll look for it.
