Groundrod testing
bwcarter
I am installing runway lighting with a counterpoise. I have to drive a groundrod at every 500ft. and test the rod before cadwelding it to the wire. I am not sure how to test it. Any help would be great. Thanks.
You may want to look at the specs on the test too. In the past I've done jobs that required a certain maximum ohm rating for the ground rod. On a couple of those jobs it meant getting ground rod couplings, then driving as many as four ten foot rods on top each other to get the desired result.
