aftershock
- Memphis, TN
What code section has the article about grouping mains on a dwelling?
I should know this but I am at a loss.
Thanx
Thanx
230.72
2008 nec
230.72
2008 nec
Why would this be a code Violation?
408.41Just yesterday I noticed the guy I work with had the panel lids off in another house and the grounds and neutrals were under the same lug in the panel. I explained that that was also a violation of the NEC code and was told that that is how the inspector wants it. By the way, whats the code section on that one?
None of these are NEC violations.6 outlets per SABC. All 110/v circuits are wired in #12 including the lights. Lights and receps on the same circuit in most cases like bedrooms and family rooms.
Also I noticed the NM is allowed to be run on top of the ceiling joists in the attic. I was always used to using the 2' rule where you measure from the top of the ceiling joist to the bottom of the rafter and anything within the 2' space can run on top of the joist, otherwise we have to bore holes. I dont know if this was a local code in Memphis or in the NEC, I just knew that was the rule.
