Originally posted by charlie:
Sam, inspection is easy. You look at the electrician, if it you, red tag. See how easy that was?![]()
Rookie."How long have you been in the trade?
"Two and a half years."
Hey, I might not have done this long, but I'm inexperienced.Originally posted by electricmanscott:
"Two and a half years."![]()
Yes, I knew it all until I started finding how much I didn't know. I am getting to the point that I don't know anything . . . but at one time, I did know everything.Anyone here know it all?
527.6 Ground Fault Protection for PersonnelHe has failed houses for not being able to find the temp GFI, there's no code requiring that, that I know of.
What Allen was getting at is that this isn't true. 250.52(H) requires a minimum of one outlet per hallway of 10' in length. The sides of a hallway can be broken by many doors, and afford you less than 2' of wall space in the entire hall; but if the length of the hall measured down the centerline before passing through a doorway is 10' or longer, you need to get an outlet in there somewhere.In a hallway you would need 10' of uninterrupted wall before you would need an outlet.
