yourflorida
New member
My local authorities will not allow a new meter service on the In-Law house I plan to build. They inform me I MUST run it off of the existing service, problem is the homesite is 500' one way from meter can.
Existing:
Meter > Interior panel/200amp main
Using the "unlimited tap rule", I could replace the meter (upgrade for amps) and install a disconnect there for the new run.
The wiresize is going to be silly (240v/150amp expected at new house).
Any suggestions?
One other idea was to have my current service moved to a halfway point, then send it to existing house panel and new house panel underground, this would cut down on oneway distance but complicates with new service location in the middle of the woods.
Desperate!! What would you do?
Existing:
Any suggestions?
