Buck Parrish
- NC & IN
I am going to need to mount a 12"x12"x4' gutter on an existing underground poco feed. The existing panels will be under it.
The gutter will stick out 8" past the front of the panels. It will be directly above the panels with in inches.
Is this code compliant ?
Their was a 4 gang meter base feeding (4 ) 150 amp panels directly below it.
We are changing it to just (2) 320 Amp meter's & bases feeding the the 4 panels.
