joerivera79
 - fort collins co
I have an electrical room with a grid ceiling, should I hang my gutter above or below the grid ceiling? Are their any code issues?
			My issues is I have conduits that need to come into back of gutter but if gutter is below grid said pipes will be below grid in the other side of the wall.
This is the reason for my first reply...I'd consider putting the gutter right under the drop ceiling where the pipes from the other side of the wall could simply 90 down into the top of the gutter. This way you can cut a big notch out of the ceiling tile over the gutter for your pipes to come through without having to make it look pretty since it isn't visible.
...but it may be difficult to put 90° bends on the conduit coming through the wall. Shepard hook, maybe... depends on distance between penetration and wireway. Alternative is another wireway or j-box or LB's.Wireway [top] @ Grid [bottom]
