[T]here is a product from ALLWALL that is a patch w/a pre cut pattern that goes around a standard size box- it is specifically for these types of booboos- you might wanna check it out.
found it
http://www.all-wall.com/drywall-patch-electrical-outlets.html
But to quote Freddie Prinze as Chico on "Chico and the Man": "Eezz not my job Man."
Grande plates.
Drywall guy a hack? No problem!
Try new Leviton Super-Gynormous wall plates.
They hide any problem!
Coming soon to a supply house near you!
:thumbsup: Dang right. On one job, the drywallers just finished their 3rd coat of mud. Several of my boxes were fully mudded in. When the drywallers left, I scooped out a bunch of mud, stood about 5' from the wall & flung the mud onto the walls. Next day, 2 drywallers were sanding the walls & 1 was cleaning out my boxes.Yesterday at the same job I dug out two buried boxes. One had a huge bulge where the drywall was bent over the box which was properly protruding 1/2" past the studs. After I freed the box, I pushed on the drywall to flatten it to the studs and make my box flush. Of course, three drywall screws popped out a 1/2". I just had to smile.Take that drywall hack!
I have run into some that will clean boxes out without being prompted to do so. They won't do it until after last coat though. If box is near a seam or corner it will get mud in it - hopefully it don't get completely filled and lost in the finish.:thumbsup: Dang right. On one job, the drywallers just finished their 3rd coat of mud. Several of my boxes were fully mudded in. When the drywallers left, I scooped out a bunch of mud, stood about 5' from the wall & flung the mud onto the walls. Next day, 2 drywallers were sanding the walls & 1 was cleaning out my boxes.![]()
There's the key phrase !!!Unless you pay me.
There was a time when I would look for my boxes with my framing hammer. Ooops, I would have bet that bump was my box I guess I'll try again...oops not there either.
I work with better crews now. No where near as common of an occurrence.
Here's another picture from the same job.
Your box is set too far back. If you set it forward enough so that it's flush with the finished wall then you won't need the device wings to sit on the drywall to keep it flush. Then it won't matter if the hole is cut too big and they need to come back and fill it in, and you won't have to worry about using fillers/levelers, etc.
I started using oversized mud rings for metal boxes and setting plastic boxes forward more than the little notches tell you a few years ago and it has cleared up any problem on my end when a crappy drywaller comes around.
Every box was set with it's face 1/2" forward of the stud it was mounted on. I don't understand why, but the drywall always seems to be more than 1/2" off the studs (and it's 1/2" drywall).
