growler
- Atlanta,GA
In order to show just how bad he could be, he did not have a bender and/or a proper fitting and/or a transition fitting for EMT=to-PVC.
Pierre that's just what you can see. If I know hacks and I have seen the work of a few. There is #14 Ga. romex pulled in the conduit ( with a couple of splices) and it's protected by a 50 Amp breaker ( that will keep it from tripping ) and the ground has been cut short ( who needs a ground). There is normally about three feet of Romex in the panel with the sheath still on and there is never a connector used. The Romex is probably streached across the ceiling grid ( above suspended ceiling and isn't strapped) and has a couple of flying splices for good measure. There is at least 10 feet of extra cable rolled up in the ceiling.
It's as if there is a contest to see how many code violations they can get on one home run and still get the equipment to magically work.
This guy may not win the contest but should at least get an honorable mention. :grin::grin:
