Where terminated in fittings investigated for grounding and where installed with not more than 6 ft (total length) in any ground return path, liquid-tight flexible metal conduit in the 3/8 and 1/2 (12 and 16) trade sizes is suitable for grounding where used on circuits rated 20 A or less, and the 3/4, 1 and 1-1/4 (21, 27 and 35) trade sizes are suitable for grounding where used on circuits rated 60 A or less. See Conduit Fittings (DWTT) with respect to fittings suitable as a grounding means.
The following are not considered to be suitable as a grounding means:
1. The 1-1/2 (41) and larger trade sizes.
2. The 3/8 and 1/2 (12 and 16) trade sizes where used on circuits rated higher than 20 A, or where the total length in the ground return path is greater than 6 ft.
3. The 3/4, 1 and 1-1/4 (21, 27 and 35) trade sizes where used on circuits rated higher than 60 A, or where the total length in the ground return path is greater than 6 ft.
