My Hilti is 35 miles from here right now or I'd measure for you. The chuck is SDS, and the size designator is TE-C. I believe TE-C bit are available in sizes from .125" to 1". The bit shanks are about .5" or slightly larger.
The advantage of SDS chucks/bits is that the chuck does not absorb the hammer action. The chuck transfers the rotory action, and the hammer action is applied directly to the motor end of the bit. So the wear and tear is on the bit, not the chuck. (The bit can slide a bit inside the chuck while rotation is constant.)
There are, IMO, only two types of hammer-drills - Hilti, and everyone else.
