peter d
- New England
LawnGuyLandSparky said:Is this really used much in commercial applications?
Sure, all the time. Most commercial jobs will have a mix of 1/2, 3/4 and 1 inch EMT for branch circuits.
LawnGuyLandSparky said:I've never bent 1/2" conduit in my life. Is this really used much in commercial applications?
Are cheap crappeter said:Klein bought out Jack Benfield so the Klein is the original, such as it were. They come with a yellow handle and are more expensive. What color is the Appleton bender handle?
Greenlee has the "StraightLine" feature whick is a little peg that you can sight down on to get your angle. One nice feature of the Greenlee is the start arrow is exactly where the end of the bending grove is.
Don't cheap out and get a piece of plumbing pipe for the handle. This will work but the official handle will be painted and the open end will be swaged so that it will fit over the the counduit so you can tweak the bend to get it exact. To get an exact 90?, I compare the bend to a nearby column or wall.
Mention should also be made of the Ericksen bend which will bend 1/2", 3/4" and 1" with one tool. It makes all bends to a super radius of 12" which helps in wire pulling.
~Peter
I remember some time ago there was a lot of talk about not being able to use 1/2 emt. It came from a lot of design/ engineer individuals. Future circuits was the concern. I always responded with "if they did not want you to use it they wouldn't make it"!LawnGuyLandSparky said:We never touch the stuff in NYC. I guess the contractors don't want to carry the parts stock for a size that's rarely needed, and doesn't cost much less than 3/4. Same logic for 1 1/4.
I don't think that the formulas are wrong. I expect that they do not include things like plumber's fittings as that radius is not permitted for raceways.The problem is to explain why the calculations must be wrong.
And that is not subjective???Dirt27 states that "bigger radius bends are much easier to pull. " I agree with him.
I don't see how driving where the forces are pushing you to the outside of the curve have anything to do with pulling where the forces are pulling you to the inside of the curve.Think of how freeway curves are laid out: Large radius.
don_resqcapt19 said:As far as using the long radius bends, it is most often to prevent damage to the conductors from what is called "side wall pressure". This is the crushing force between the conductors and the inside radius of the conduit when the wire is pulled. The side wall pressure is found by dividing the pulling tension at the bend by the radius of the bend in feet.
mdshunk said:The GB and Appleton benders are the bastard one's, since handle straight up on those is 45 degrees instead of 30.
JohnJ0906 said:Not true of the GB benders I have. (?" and ?") Both are 30? handle straight up.
