I have run into a situation where the homeowner is providing some very expensive hand made fixtures. The problem is that none of the fixtures have come with a ground wire or supporting brackets. The ones that will be hanging from the ceiling weigh well over 90 lbs. each and have no support cable fasten to a structure member. Has anyone else run into this situation and what did you do.
