Re: Handbook's diagrams, are they correct?
Exhibit 314.3 on page 326 of the ?05 Handbook shows the equipment grounding conductor being taught to the grounding screw and extending to the wire nut.
This could be debated as Bob has pointed out by 300.14. Also, it could be debated that this box should have been bonded by the #12 conductor as outlined in 250.122.
The one thing that should be considered, this exhibit is used for the box fill calculation.
In my opinion this exhibit should not be used for anything else but box fill. As well exhibit 314.5 for surface extensions from a flush-mounted box has the equipment grounding conductor pulled tight to the ground screw.
The exhibit used for 300.15 (exhibit 300.14) does not show the ground being pulled tight nor does exhibits 250.2 & 3 in grounding.
250.53 (G) states that a rod or pipe electrode can be buried at a depth of 30 inches but Exhibit 250.23 of the 2002 Handbook shows 2 feet (24 inches). This was corrected in Exhibit 250.23 of the 2005 Handbook.
This also leads me to believe that the Handbook is policed and is a very dependable guide for students in all fields of the electrical trade.
