funny how i was just dealing with this issue of using "'U L' listed for the purpose "
Had a an OLD breaker (squared D) go out, and originally they had a 'top and bottom' tandem (peanut) breaker they used and had a nail between the 2 tandem breakers and it worked fine for 30 years it seem. They do not make top and bottom tandems any more. just side by side.
Problem is i could not use side by side in this panel box
!! I was bummed thinkin i might have to change out the whole box but i was able to find an old used top/bottom tandem breaker.
I went and got the 'UL listed for the purpose' PINS to put between the breakers to cause them to trip together. Problem is that with this 'square d' pins with these 'old tandem breakers' almost would NOT let the cover be put back on cause the opening on the cover wasn't wide enuff because of the pins!! . ARRGH!!
Not say i justify not using the 'UL LISTED for the purpose' products but in my opinion the old nails worked better and were more rigid, and more safe!! I can see how an inspectors let it go in the past and in my opinion was a better way to deal with it and safer.
