hanging 4' floresent lights off of emt
gilrod
New member
if you run 3/4 emt 30' up in rafters and put twistlock plugs at this hieght. can you hang chain or wire off of conduit to hang your lights down at 20'?
Little Bill
Tennessee NEC:2017
Semi-Retired Electrician
Are you using the EMT as a raceway (conductors running in it)? If so, then 300.11(B) IMO would prohibit this.
jmellc
Durham, NC
Facility Maintenance Tech. Licensed Electrician
You could install a separate EMT and hand light from it, but not the conduit you install as a raceway.
