Stevenfyeager
- United States, Indiana
- electrical contractor
Hi, is it allowable to install a surface mounted light fixture or hanging light fixture over a bathtub if the ceiling is 9 feet high? Thank you.
A chain hung or pendant fixture needs to be 8' above the room of the tub.
room (type error) "rim"
With only a 9 ft ceiling, I guess my customer is out of luck.room (type error) "rim"
They could always install a CANDLE chandelierHi, is it allowable to install a surface mounted light fixture or hanging light fixture over a bathtub if the ceiling is 9 feet high? Thank you.
So the only light fixture I can offer is a recessed light, correct?They could always install a CANDLE chandelier
Sent from my Pixel XL using Tapatalk
410.10 (D)
Luminaires located within the actual outside dimension of the bathtub
or shower to a height of 2.5 m (8 ft) vertically from the top
of the bathtub rim or shower threshold shall be marked for
damp locations, or marked for wet locations where subject to
shower spray.
Thanks, that makes perfect sense. I appreciate it.You need to make two determinations, is it within the so called 8'X3' tub zone and if so is it subject to shower spray. If it's outside of the tub zone then you can install any fixture type including a chandelier or paddle fan. If it's within the tub zone but not subject to shower spray then it needs to be damp location rated. If in the tub zone and subject to shower spray then wet location rated.
You can get ceiling fittings that have a lower profile than one foot.With only a 9 ft ceiling, I guess my customer is out of luck.
A quick and dirty search brought up this. I feel sure you can get similar there.
https://www.qvsdirect.com/lunar-28w...=2d635bec71e5c8fa42fb1cc41fddabd7&fo_s=gplauk
If the bath in the magazine has a 12 foot ceiling it may very well be code compliant. Now your client wants to have something just like that picture but only has an 8 or 9 foot ceiling:blink:I really wish they would stop featuring chandeliers over tubs and in clothes closets on design websites and TV shows. I am constantly having hard conversations about that not being a safe or legal installation in spite of it being shown in a fancy magazine, etc. Drives me crazy.
So a surface mounted light can be lower than 8 feet above the tub rim ?See attached...![]()
Yes, was earlier mentioned though it must be damp rated or if subject to shower spray must be wet rated.So a surface mounted light can be lower than 8 feet above the tub rim ?
