jb, You could say that the currents are "bent out of shape" by the non-linear loads.Originally posted by jbwhite:
so are the total currents just being displaced in time, and not being created?
what i mean is if i have ten amps per phase, can i ever get more than 30 amps back on the neutral?
Be cautious about thinking amps as they apply to 60HZ and amps related to higher magnitude. The values we are used to in 310.16 go out the window because of the higher frequency creates more imepedance and lowers the ability of the conductor to carry the added current. Or so I have been told by some pointy heads.but, with each harmonic the amplitude deminished. is this true with current?
No, only fundamental frequency is at 60 HZ, the harmonics are a separate voltage created by the currents which are drawn asymmetrically by the load. The effect is to impress themselves upon the fundamental frequency, thereby distorting the 60HZ waveform for both currents and, in worst case, voltage. The harmonic component is still there in the conductor at the frequency of all harmonics and the fundamental. The RMS meter value will give you a relative to 60HZ current based upon the different frequencies present.Let make sure I got this right. the harmonic wave is still at 60hz. but we use higher Hz to mathematically describe the distorted wave. impedance would still be the same.
