Have Backstabs Improved?
  • I have experienced the improvement.
    Votes: 1 1.2%
  • I think they are now as reliable as screw connections.
    Votes: 6 7.4%
  • I think they are now reliable and always were.
    Votes: 11 13.6%
  • I think they are good enough.
    Votes: 9 11.1%
  • I think they are still unreliable after the design change.
    Votes: 23 28.4%
  • I have experienced their unreliability.
    Votes: 36 44.4%
  • Total voters
    81
Sammy G
New member
Port Orchard, WA
When backstab receptacles started accepting only #14, it became possible to design them for better reliability by applying more force to the #14 wire than before. Has anyone had real-world experience that says they are now reliable or that they are still unreliable or that they are still unreliable? What about long-term reliability? How long ago did this change take place? Can anyone refer me to a study of the improvement?
I enjoyed the Backstabbing Pole at http://forums.mikeholt.com/showthread.php?t=91799&highlight=push-in
The possibility of such an improvement was brought up by tallguy, but no one followed it up.
Mule
Oklahoma
Ive never seen a a backstab failure in a general lighting recept, but I have seen several in more heavily loaded places...
Brian Johns
Kansas
I just refuse to backstab any device and honestly, i wish they would ban these types of connections, too many times have i pulled an outlet or switch only to have a wire pop out of the stab. I go so far as to tell my home owners that all of my terminations are done with twisted wires and wire nuts, and all devices are wired to the screw. It takes time and i think it is worth it.
every time a load is applied, that little pressure joint heats up, then cools, then heats up, i believe it takes the spring out of the metal, annealing it, thus a bad connection and just more heat the next time.
brantmacga
Señor Member
Georgia
Former Child
i've never experienced a problem with backstabbing, and i've never seen one fail. makes installation a breeze; i like them. i was actually disappointed when they stopped making them to accept #12. that was when we switched from #12 throughout in residential to using #14 where allowed. never looked back.
wawireguy
Guess I don't think about it much.. If a customer were to tell me they want to pay for the extra labor for side wiring receps I'd be more than happy to give them what they want. But when it's bottom dollar bid the customer gets a UL, NEC approved back stabbed intstallation.
stickboy1375
Litchfield, CT
Nothing wrong with back stabbing, I've seen in my years of experience just as many bad splices as very old back stabbed receptacles... get over it, the practice is fine in my opinion.
480sparky
Iowegia
But you have more control over a splice than a backstabbed connection. With a splice you usually see your work before the wire nut goes on. With a backstab, it's poke and hope.
stickboy1375
Litchfield, CT
I'm not going to argue this, all I can say is that Celtic agree's with me. :grin:
Cavie
SW Florida
Don't do much service work do you. My house was built in 1989. I bought it in 2003. When replacing the outlets, 1/2 the wires pulled out of the backstabs..
Minuteman
Was on a service call last week, where an old style backstabbed neutral came loose and effected most of the living room. However, since we don't use anything smaller than #12, nobody backstabs anymore.
Buck Parrish
NC & IN
The problems seem to happen most when their is a load such as a electric heater or iorning board. I don't back stab. But, I like for others to. It makes for more service calls for me:wink: . I'll put my wood head in an outlet. Then go around the room and wiggle the other outlets. That is a way to find the problem.
steelersman
Lake Ridge, VA
I'm with you brother man. I just saw in Lowe's the other day 15 amp ones that have 4 stabs on each side hot and neutral. Awesome!!
sparkyjim
Dallas, TX
The Master I originally trained under said it was just like on the play-ground, "No one likes a back-stabber". I have never used the option; it's the first thing I, or the service techs, look for when on those mystery outages at residences. I do understand it is a labor/time saver, but we don't do trac homes so I've never had to worry about the labor difference.
